Old 07-09-2003, 03:23 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Given the rest of the engine combo you stated(dual plane intake, factory heads), you would probubly be happier and faster with less duration. What is your intended working RPM range, because that cam wants some high RPM. Whaen it comes to cams, smaller is usally better, contrary to what you want to believe.
