Old 07-09-2003, 09:31 PM
Ray R Ray R is offline
Default SPF Owners/Builders w/351W+
I'm putting the finishing touches on my SPF #1649. I'm to the point where I'm connecting water hoses, and am working on the hose that connects the upper port of the water pump (5/8" hose fitting) to the port on the neck of the "header" or "puke tank" (looks like 3/4" hose fitting). The port sizes are different. The angles are a bear!
The water pump I was sent as part of the install kit is a Carter with fixed hose connections. The hose they sent as part of the install kit is 3/4" on each end, and looks like crap when mounted.
What are you guys using for a solution to this? Please post pictures if possible.
Thanks!
Ray
