  #26 (permalink)
Old 07-11-2003, 03:10 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Gerry - I would have thought that was a pretty extreme cam grind to exhibit that effect, could you post the specs for us ? Matching the power valve to the engine vacuum characteristics is a step well worth doing. It would be a simple matter to temporarily hook up a vac guage and run the pipe back to the cockpit to see exactly what is happening at different throttle openings.
Be careful though - when I did that I was concentrating so much on the guage I nearly drove off the road!
Now you have to get your builder to explain the excessive blow-by.
Luck.
Wilf
