Old 07-11-2003, 09:55 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If you lift the engine with a chain bolted to two intake bolts, it will only be a matter of time before you need to put thread inserts in those bolt holes. Frontand back of the heads is where I recommend, An engine tilter is very nice to use as well.
