Thread: FI on an FE
Old 07-11-2003, 10:50 AM
Lew This injection system work the same as TWM. You have a throttle body for each cylinder, 1 injector or two depending of the motor. You need a laptop to program it. It the same as you car or truck with FI. you will have an O2 sensor in the exhaust, map, inlet air temp sensor and coolant sensor. The trottle position sensor will be on the throttle body. You will need a electric fuel pump with 40 psi output, min 3/8 fuel line and 1/4 inch return to the tank. You will need to go to a good dyno shop and have them set the car up. 2-4 hours at 100.00-125.00 per hour. It will work better than a carb, except at high rpm over 6800. You may want to look at TWM's web site too. There system looks closer to the orginial webers. Both are great systems. Rick Lake
