  #21 (permalink)
Old 07-12-2003, 09:31 PM
decooney's Avatar
decooney decooney is offline
Default Hi Paul...
Hi Paul,
no problem, i'd prefer to send the specs to you directly. Another thing I would recommend is for you to seriously consider how you will "actually" be driving the car, on what type of roads, will you get stuck idling a bit in traffic getting to your destination, etc.... Along with the cam, getting your carb dialed spot on makes a big difference too. But, the cam is the Brain to me.
After making my decision on the final specs to use (and after multiple David Crower conversations), just to be sure, I ran it through again over and over on various cam software programs using various types of trans/differential gear ratios, compression, etc... and the cam spec changed more than I would have imagined on different types of open or tight road coarse tracks and conditions. I'll send you an email. Please be sure to recheck what I've come up with because selecting a cam that is right for you and your expectations is important.
Duane
