The complete stock Versaille setup is a popular swap into early Mustangs. The width is correct. I thought it was a necessary item for my application but after seeing the calipers I chose to look at something lighter. Suggest you chose any 9" Ford rear housing and narrow it accordingly Dave: I have not had it on the road with this setup yet so I cannot answer your question but I am hoping that my efforts are worth it I'm about 6 weeks from being done. I got the brackets from Currie Enterprises in Southern Calif. The bearing retainers have provision for two 1"x3/8" bars that are secured to the retainer plates by (2) 7/16" bolts. Then the bars also use (2) bolts to attach to the caliper. I sourced just the brackets from Currie. Everything alse was gotten from either the parts house or wreckers. 88 Tbird Turbo Coupe, 77,78 Granada
I have other pictures but they are to large for this site. If you would like I can email them directly to you.
Rick
