Old 07-14-2003, 09:49 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
As an SPF owner w/ pin-drive Trigo's, I've had some experience that has been mentioned by others on this thread.
1) Anti-sieze. I can't stress this enough. You'll never need a 'special tool' of you use anti-sieze correctly and often. FWIW, the SPF factory does not recommend using a 'special tool' tighten the knock-offs...you simply cannot get sufficient torque with one. Use a lead hammer for both removal and attachment.
2) Safety Wire. I do not like leaving the wire slack and then looking for a tightened wire to determine if a knock-off has moved. You'll wind up asking yourself just how much slack you left in that wire when you put it on. I much prefer making the wire tight, but using it opposite from the way one would normally use safety wire. Normally, you use safety wire to prevent something from loosening. But, no safety wire is strong enough to prevent a knock-off from coming completely off. So, don't lull yourself into a false sense of security...even when safety wired, a improperly installed knock off can come off! Rather, I prefer to use saftey wire to pull against the knock off ear in the normal direction of removal rotation. In this manner, if the knock off moves, the wire that you know you installed tightly will suddenly have some slack in it and you'll know you need to take few licks with that lead hammer.
3) MAINTENANCE! Check your knock offs each week...even when safety wired. I walk around my SPF every week and whack on one ear of each knock off with my lead hammer a couple of times. I've only seen one move...and that was only a fraction of an inch, but enough to alert me it had moved! Also, a satisfying 'thunk' will tell you the conical shaped mating surface is tight against the wheel. Finally, remove your wheels and knock offs at least once a year to re-apply anti-sieze and look for corrosion, more often if you live in a damp climate or wash your car frequently without a short drive immediately following to dry everything out.
Hope this helps. Many of these tips have been gathered from other SPR owners, SPF dealers, and the SPF factory itself, as well as Lynn Parks, owner of Trigo and an original Cobra owner, as well, plus a lot of personal experience.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
