Old 07-15-2003, 08:06 AM
John Poling John Poling is offline
Roscoe and Casaleenie,
I have already done this. The individual that originally started this kit had them balanced using the tape weights inside the wheel. I did not like this so when I had the car put on the rack to check 4-wheel alignment and do the front end alignment, I also had them balance the wheels using weights on both inner and outer rims. I later had the 2 front tires replaced as they were egg shaped, so when I did this, I had them rebalanced and also check the balance and roundness of the rears. I was for a split second concerned about the weights on the outside of the wheel but then decided that because these things are so wide that they needed inner and outer weights.
Roscoe,
When you get a chance, will you please measure how high off the ground your main frame rails at you rear lower control arm mounting point is? And, Are your rear lower control arms parallel to your 2X4 main frame rail? How tall are your rear tires as measured sitting on the ground?
Thank you for the input.
John
