Old 07-15-2003, 10:22 AM
John Poling John Poling is offline
Roscoe,
I will check those measurements to mine and see what the difference is. Height wise we are running about the same size rear tire, mine is a 315/35-17 which equates to just over 25 1/2". My rear lower arms are also at an approx. 6-8 degree upward rake from the front, this concerns me from a performance angle as suspension twist is going to make it even more off. Since you do race yours, have you ever experienced any rear traction/handling problems? Other than wheel spin, Do you notice any swaying in the rear upon acceleration or deceleration?
Also, does your driveshaft go uphill from the rear of the transmission to the pinion of the rear end? If so, about how many degree?
Thanks again.
John
