Old 07-15-2003, 11:00 AM
Mohuska DON"T DO IT!!!! that takes care of that. I have a FAST ECU with sequential for spark and fuel per cylinder. Hook up the laptop and tune. Do we have a pernup??? Who gets the cobra Sorry been down this road in NJ. Now been living with someone for 15 years, no problems. Really GOOD LUCK and Good WISHES. GET ALL YOU CAN, The Honeymoon will soon be over. I think there is a problem at high speed with the webers because of air flow. Build yourself an air box that goes to the hood scoop. I think at high rpm that the air directs over the top on the webers and is not forced down the throats. With a air box, you pressurize the whole area and it is like a blower pushing air into a motor without the blower. If the heads and intake are port matched you are getting 20-40 hp over a carb. at the top end you are going to lose out once max flow is reached. Mid range power you will win out. You would think that 3,200 cfm of webers could not be outflowed by a 950 holley carb. Rick Lake
