Old 07-15-2003, 11:17 AM
John Poling John Poling is offline
Roscoe,
Okay, I was told 0-3 degrees is the range that is acceptable because of the stress that the rear u-joint can take over the long run. Mine is in the neighborhood of 8-10 deg up from the transmission which could be over stressing the rear u-joint and making it do funny things.
Other than the upper arms is your rear suspension the same as A&C supplied to you. Have you added a sway bar or panhard bar? Did the new adjustable uppers use the stock mounting points on the housing and frame?
Thank you
John
