Old 07-15-2003, 11:27 AM
Roscoe's Avatar
Roscoe Roscoe is offline
Other than the uppers the rear is exactly as it came from A&C.
1" Sway bar on front only.
We had to grind a bit here and there on the Metco uppers for a proper fit but they work fine. I had to go with the adjustable uppers cause I couldn't get the pinion angle right and the driveshaft was binding.
Personally I believe that A&C used two different chassis jigs over the years and they are slightly different, especially in the rear.
The hump that goes over the axles is different on mine than my friends who got his about 3-4 years before me. My roll bar mounting brackets would not fit properly due to the distance between the hump. Apparently A&C did not allow for this with different brackets and I believe the same is true for the control arms. Now I don't know if I am right but that's how I see it.
Anyway, no problems that can't be corrected.
Roscoe
Roscoe
