Old 07-15-2003, 04:44 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Chopper-
Machining down the boss also solves your second problem with the filter hitting the x-member b/c it effectively moves the bracket backward by the same amount that you cut-off. However, it sounds like you've found an acceptable alterntaive solution. And please, no need to call me Mr.
Replica is not a dirty word.
