  #25 (permalink)
Old 07-15-2003, 06:59 PM
Monster's Avatar
Monster Monster is offline
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
This is a great thread for us "original replica owners" (after all Arntz was the first).
I was wondering how your front ends are currently set up. Maybe we can learn something from each others current setup.
I have:
MGB crossmember with stock oilshocks and lower A-arms. Nylatron bushings, stock spindles, 11" Chevy rotors, 4 piston JFZ calipers and HD springs (not sure what weight but they are not stock)
The bushings helped out, JFZ is out of business and I would like to change them out due to they drag at times. I did retro-fit a 1" anti-sway bar, but I broke the one of the aluminum heim joints I use to mount it (probably need steel). But it did help the handling quite a bit however it may have been a bit to stout. Also, I am running 275/50's up front which I feel are to wide and make steering a chore. I will change over to 245's on the next set. I do like your 17" wheels though, Pete.
so how are you setup??
Thanks,
Mike
