Old 07-16-2003, 12:52 AM
Ant Ant is offline
Default Transmissions
Cal Metal,
I had a big shaft TL behind the FE, great transmission, but quite heavy and of course being heavy they handle almost anything. I dont know whether its worth going to a lighter trans, as they dont last.
Regarding the TKO II I can't be bothered with the high overdriven fifth gear, even though cruising in a low revving machine is good, I am going to run 3.08 rear gears, and would be quite happy with a 1.1 top cog!
A lot of guys run a very steep rear end ratio, I suppose this leaves the bottom four ratios quite low and closer, and utilizing a .58 fifth gives a good cruising number!
A J. Newton
The 1960's rocked!
