  #23 (permalink)
Old 07-16-2003, 07:15 PM
CSX 4027's Avatar
CSX 4027 CSX 4027 is offline
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Jam
Thick oil if you race and turn high oil temps and high rpm. It will give you the protection. If you have a street car and a 351 built with modern hydraulic or roller, lighter than what you are using could be better. It will take less time to get to proper temp and your car will feel faster. Drag guys use light weight oil for a run on the street. The crank has to work harder to turn thick oil. If you are not running over 7000 rpm, I would go lighter. Check with your engine builder.
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
