Old 07-17-2003, 06:20 AM
DavidFagan DavidFagan is offline
Cobra Make, Engine: Excaliber, Ford 5.0
Default Re: David: MFG#
Originally posted by ohekk
David,
Perhaps I missed it?
What is the MFG# of your Excalibur? Color etc?
Do you know of any others?
Milw Doug brought his to the weekly cruise last night...what a beautiful car!
Thanks
Tom
PS We've located 42 to date!
I thought I posted this, maybe not ....
If you need all the numbers let me know but it ends with 138 so I think it's very near the end of production. Ford 95 5.0
Yellow w/ black stripes
Don't know anyone other then on the site.
Problems. Cracked headers
Have new ones which are much stronger.
So far I have replaced the right which was totally trashed and put in a support bracket down to take the weight off the headers. I hope this was a weight and not a rigitiy problem or I'm going to have to revist this again because you could lift an engine with the exhaust system STIFF! The left side is just starting to crack but I want to drive the car and put this off until the winter. Support on that side will also be more like real work due to the wiring and brake lines. I suspect I'll also have to pull the steering column but I've done that before to modify it, it was to wiggly for me.
