Thread: Brake Lights?
Old 07-17-2003, 08:23 AM
Dirty Harry Dirty Harry is offline
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
Do you have a pressure activated switch or a mechanical switch? Either way, find the switch. Verify with a 12v test light that power is being received at the switch. Use a short length of light gauge wire with a small fuse in the middle to shunt the 2 contacts together. An assistant can tell you if the lights came on or not. If so, suspect a switch problem. If not, the problem is somewhere between the switch and the lights. On the other hand, if power is not being received at the switch, the problem is in the fuse panel or the wiring leading to the switch.
When I said I wanted to be somebody, I probably should have been more specific...
