Thread: Brake Lights?
Old 07-17-2003, 08:36 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Check your brake pedal. I bet it has the old style GM brake light switch that has a button that rests against the upper brake pedal. If so, it may just need adjusting.
If you find this is the type of switch you have pull both wires off and wrap some tape around one of them while you are working on your switch because one is always hot and if they touch you will blow a fuse. It doesn't matter which side they go back on the switch either your brakes lights will work as long as both wires are connected.
Clois
"Let's roll"
"Be part of Something Good
