Old 07-17-2003, 12:40 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
As stated earlier, check to make sure the carb is opening the throttle blades completely, I can't tell you how many times I have seen that one. If you have a vac secondary carb, only the front will open with the gas pedal, the rear needs a vacuum signal.
