Old 07-19-2003, 11:07 AM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default Help! Broken pipe!
Hi,
I was changing cams this week and on the downhill side reinstalling parts. I went to install the oil pressure sending unit and snapped the brass pipe fitting that screws into the block. I don't think an easy out or pipe remover will take it out. I can drill it and pull the treads out ( or re-tap it), but the engine's in the car and I have the shavings problem. I thought of removing the filter and running air back through the system as I drill it to keep out any brass shavings or slowly turning the oil pump with a drill to force oil out the hole as I drill it, but I'm hoping there's another way to possibly take care of this short of removing the engine and doing a complete tear down. Another option would be to tap the inside of the broken pipe to a smaller size and install a smaller fitting with a hose barb and run the sending unit remote with hose connecting it. I'm out of ideas, but don't want to do anything in haste without thinking of all the options.
I need ideas badly!
Thanks,
Bill
