Old 07-19-2003, 01:52 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I did the same thing a couple of years ago. Go to sears and get one of their easy out sets (about $30) and tap the easy out in lightly with a hammer then spry wd 40 around the fitting and wait a couple of minutes before you attempt to remove the broken fitting.
I believe the pipe is 1/4" brass so be sure the kit has an easy out that will fit that piece of pipe. You can do it from under the car easier. Good Luck!
Clois
"Let's roll"
"Be part of Something Good
