Old 07-20-2003, 12:33 AM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Rick,
I had one laying around from the old Mustang engine. It looks much better, but I'll have to check for clearance when removing the oil filter..it's close. The brass pipe configuration put the sending unit a bit closer to the block, but at a better angle to allow removal of the oil filter through the top....I'm not sure the hex tube will allow that. I'm sure gonna try though...You're right, it's a lot beefier.
