Old 07-20-2003, 08:08 AM
ted ted is offline
Default Wanted - a single M-W 35 spline axle
I'm looking for a single Mark Williams 35 spline axle. All that's technically required is the end seven inches including the splines so I can make a tool out of it. Only the end two inches of spline need to be usable but need at least five inches beyond that for a stub. Only Mark Williams will work as the M-W uses a spline angle that is specific to only them and is not an industry standard.
Either post a response here or email me if you can help.
Thanks, Ted.
Ted Eaton.
Fe's are fast but "Y-Blocks" are fun when they run in the 9.60's at 135 mph.
