Old 07-21-2003, 09:04 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Replace the large diameter alternator pulley from the pulley set, and reinstall the small diameter alternator pulley that came on the alternator, see if that helps. You could also add a temorary voltmeter, that will let you know if the current drain is sufficient to actually lower the voltage.
