Old 07-21-2003, 10:55 AM
Dan Semko's Avatar
Dan Semko Dan Semko is offline
Hoosier Gashole Emeritus
Wink
Frank,
I think that your problem is probably from a bad diode in the alternator which will not reveal itself without a metered check.
I had a similar problem with a new alternator but fortunately the Mike at Dynamics caught the problem before it killed the battery.
Your alternator is probably going to quit which is usually indicated by rapid spiking in either direction,of the amp needle. Before you change the alternator, check the battery terminals first because if they're loose, it will cause the MSD to malfunction and could easily mimic the symptoms you're experiencing. If they're firmly seated, then I'd guess the bad alternator will rear it's ugly head soon.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
