Old 07-21-2003, 07:48 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
I'm looking at the rear light harness, P3-58, and front light harness P3-63.
On the front harness, wire #167 goes to the front right turn light, #168 to the left turn light, and #147 to the front parking lights. And you're saying that these work. And the emergency flashers work.
On the rear harness, #169 goes to the left turn, #170 to the right turn, #147 to the parking lights, and #165 to the brake lights.
If you have discontinuity at the fuse block, a fix might be to splice #'s 169 & 168 for left turn, 170 & 167 for right turn, front #147 and rear #147 for parking. Do this on the engine side of the firewall. No permanent connections until everything works.
If no power on the engine side of firewall to #165 which is your brake light wire, drill a small hole through the firewall under, or alongside the fuse box. Take the #165 wire where it does have power from the fused circuit, connect it to a short length of wire and push it through the hole you just drilled (1/8" - 3/32") and connect to #165 on engine side of firewall.
Everything should now work. Trial assemble this and tell us what happens.
Petek, do you agree with this?
