Old 07-22-2003, 04:24 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Smile drill
Drill the center of the bolt and put either an "easy out" or a rod into the hole.
If you can not back the bolt out with the easy out, put the rod in the hole and tack weld it in place. Use a puller and remove the bolt.
I believe the head is gone?
Hope this helps.
