Thread: T5 Question
Old 07-22-2003, 04:52 AM
dalola's Avatar
dalola dalola is offline
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Cool
Along with the comments of these gentlemen, rear gear ratio and tires also factor heavily into how long this trans will last. Cobras being relatively light will help, but if you are running a steep gear(3.73&^) and sticky tires, forget it! Also, the condition of the trans initially may be suspect. If it was abused in the donor car, it's days are even more numbered. Of particular concern in these trannys is where the input shaft pockets into the main shaft. Very susceptable to wear here. Run it as long as you can, but don't be surprised if it gives up relatively quick, depending on all the above mentioned criteria. Good luck!
~Dave
