Old 07-22-2003, 06:42 AM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
Sounds like a great way to bypass the problem Jack. Should work fine and w/o any problems.
I'm still wracking my brain on this one. The problem could be in the fuse box as Art says ... or the problem could be in the column switch.
Art, if the new fuse box doesn't work give a holler and I'll see if I can find the pin-outs to the column switch and walk you through bypassing the column to test the lights.
Pete K.
Who is John Galt?
