Old 07-23-2003, 10:54 AM
Cobraearl Cobraearl is offline
Our event requirs Snell 95 or better helmets. SA or M is Ok. A DOT certification only is not good enough,, SNELL 95 or better, guys.
there are no classes that require drivers suits.... however for the Advanced Class, they are reccomended. For the Advanced class, I would HOPE these people also have the SA helmet. but either is allowed.
There will be limited passing allowed in all classes... passing only in restricted areas and ONLY after the car being Passed CLEARS the passer to pass. no Tailgating in the turns either.
After your registration form is received, you will get a More Comprehensive set of information... to include the tech inspection form, the track rules, the event rules, the motels in the area, etc, etc, etc.
What kinds of cars are allowed?? Cobras with roll bars and other cars that would run safely and blend well with cobras.... like corvettes, high powered mustangs, etc. Cars that weigh OVER 2000 Lbs. with 11 lbs per hp or less. NO OPEN WHEEL CARS. ALL roadsters and convertibles must have Real Roll Bars.
The lower powered FFRS are 225 hp and 2250 lbs which figures to 10 lbs per hp. We are sort of using these cars as a base car for the event.
The registration form asks you which class you would be best suited for...... Novice, Intermediate, Advanced, Ladies. We reserve the right to ballance out these classes, if necessary, by judging your experience level, wt/hp, type of car and tires.
BTW, the registration is COMING ON STRONG....
DOWN LOAD THE NEW two page REGISTRATION FORM, read it, and REGISTER NOW!!. You can register by FAX today or THURSDAY and Get the Extra FREE EVENT TEE SHIRT for Registering EARLY. Early Registration ends at end of day, THURSDAY. so you have less than 36 hours to get the extra FREE EVENT TEE Shirt.
earl
