Old 07-24-2003, 08:06 PM
smokintires smokintires is offline
Default Problems shifting in reverse
Got a question for all you gearheads - I've got a Tremec 3550 behind a 351W. With the clutch in and the trans in neutral and I try to shift to reverse, the gears grind, but if I shift into 4th then immediately into reverse, there is no grinding. Anyone know why or suggest a fix? Thanks in advance.
Mike
