Old 07-25-2003, 05:28 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default How do you know if you have a bad Coil or Ignition Box????
After work yesterday I got in my Cobra and tried to fire it up for a little mind de-tuning ride. Starter spun like crazy and I was getting plenty of fuel but it would not fire. Checked coil wire and there was no spark. So I checked all my connections first and found a loose ground wire at my block. Tightened everything up and turned the key on and the beast came to life.
So I got to thinking, (scary huh?) how would I know if my ignition box had gone out or if I just had a bad coil? Is there some kind of test for this or do we just start to replace parts until everything is working again?
Clois
"Let's roll"
"Be part of Something Good
