Old 07-26-2003, 04:19 PM
rms427 rms427 is offline
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
From what I found the Racedeck is going to cost $3 to $4 per square foot installed. That assumes you will install it yourself. The installation is very easy. The cost difference is the amount you buy, delivery charges, tax and how many tiles you end up cutting to make it fit. I cut the tiles with a radial arm saw and hand held jig saw. A table saw would be better than the radial saw since you could set it up for a number of cuts and then just do it. The only screw ups I had is that a few times I cut the wrong color tile for a specific location. In most cases I was able to salvage part of that tile for another location so it really didn't cause much of a loss. The tiles are directional so that when you cut a tile you may or may not be able to use whats left in another location. I found that with some planning I was able to use what was left of tiles I cut in other locations. But you will have some waste no matter how you do it unless you don't have to cut any tiles.
