Old 07-26-2003, 05:19 PM
Slow Dawg's Avatar
Slow Dawg Slow Dawg is offline
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Yeah, pull it off and install a rear sump pan. If you find a stock pan, see if the drain plug is on the bottom. Good chance it is. We cut the bottom off and weld on a 3/16" flat stock steel and weld the bung on the side. Just make sure the sump doesn't bottom out on the pan. That thick piece on the pan takes a lot of abuse.
Nonconformist. Can't handle a real job.
