Old 07-28-2003, 05:59 AM
Curt C The alignment is good? car goes straight without holding the wheel? You have bleed the system a couple of times? Are the brake hoses rubber or braided steel lines? Try this first, If you can, swap 1 piece at a time and test, do the brake pads first, any change? try the rotors next, make sure you tight the bearings to spec. IF nothing fixes it they sell a tester that goes between the pads to check pressure to make sure they are the same. You could have a pinched line in the piping? Start with the basics first. You may want to add your wieght to the passenger side and see if the problem is still happening, I am not trying to be smart, just balance the car out. Stay in touch Rick Lake
