Thread: Sumer Fun
Old 07-28-2003, 01:59 PM
BPWilliams's Avatar
BPWilliams BPWilliams is offline
Cobra Make, Engine: none
Cool Sumer Fun
Well here is a Cobra up-date!
The motor is still in pieces after the push rod broke, then the intake valve push rod bent. I am glad that the car is not running because it is to darn HOT to drive!! You see this is my first summer having the Cobra, and I had visions of driving every day, thinking that the heat's not that bad, boy was I off base. I decided to do the little things that make a car. I finished off the trunk with carpet, and painted over the overspray from when I did the paint. I also put screen in the oil cooler vent in the front of the car, hopefully it will save on rock damage? I also got an itch, speaking of rocks, and repainted the front of the car from the damage from Route 66. (The stickers were getting old) I had to custome order the push rods for the geometry of the valve train, and it will be several weeks before Crane can deliver. So it looks like I am going to put the Aluminum shroud in the nose while it sits there. Hopefully I will get a chance to drive her again in the middle of August, when it cools down!
To all those gear heads stuck in the garage!
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
