Old 07-29-2003, 11:04 AM
Charlie Hi You have the right coil for the 7al? You are using he blaster SS or HVC coil I would stay with the MSD wires 8.5 super wires. You are using the wire spreaders and not letting them lay on the headers. If you spray a mist of water at night you can see where the spark is coming through the casing. If you want to stay blue with the color try the 11 mm super max from moroso. Something is causing the case to break down. Did you open up the gap on the spark plugs. With this set up you can go another .010 larger. It will not hurt anything. Rick Lake
