Old 07-29-2003, 11:32 AM
Charlie Charlie is offline
Rick,
Thanks for responding. Actually, I made a mistake in my earlier post, I have the MSD Digital-6 Plus box, P/N 6520, not the MSD-7. But in any case, no I don't have the recommended MSD coil. I am using the Ford canister type coil which came with the engine from the SVO factory. It is supposedly designed for use with the Duraspark-II (?) system with the wide distributor cap, so I guessed (maybe incorrectly) that it was designed for higher output. I kept it cause it had the correct look sitting above my engine, and seemed to work.
I opened up the spark gap considerably. I don't remember off-hand how much, I will have to measure one. Wires are in looms and not anywhere touching the headers.
I haven't tried the water spray at night trick. That is a good suggestion. I will give that test a try as a diagnostic tool. Of course, it doesn't point out WHY this is happening. I am beginning to just think Motorcraft wires are not very durable, but I don't want to blame them for something stupid I am doing wrong.
Any idea why a different coil would cause the wire casings to break down? I would think that any quality performance wire could withstand the power from a standard high performance coil like this. I think the MSD coils put out more spark energy than this Motorcraft coil does.
Thanks for your assistance Rick.
Charlie
