Thread: Camzilla
Old 07-30-2003, 01:42 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I have an extra Competition Cams roller cam for sale if you're interested. It's .530 lift with 1.7 rockers and .500 lift with 1.6
Duration is 285 intake 291 duration and the lobe centers have been set to give it some low end and good vacuum while still letting it have a nasty sounding idle..and trust me...it has a NASTY idle!. It pulls like all getout from 2500-7000+. It was a custom grind for me from Comp to fit what my Cobra needed. Let me know if you'd be interested...it's a proven grind ( to me anyway) and made 529 flywheel hp in my motor.
