Old 07-30-2003, 08:12 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
Frankym,
Typical production CV joints have about 1.5 degrees radial play.
Production plunge (Tripoid) joints have about 2 degrees radial play.
Therefore, if you have CV's on both ends of your halfshafts, you would expect about 3 degrees of play. That extrapolates to about .75 inches at the outer tire diameter on a 26 inch unit.
With a CV and a plunge joint, you can expect about 1.15 at the tire.
Your problem seems to be more in the diff. Possibly excessive play in the spyder gears?
Best regards,
Richard Hudgins
