Old 07-30-2003, 10:38 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Post
For overhead radiant heat I suggest either Dayton or Vantage(could be Pro Vantage?)--they are sort of the Rolls/Bentleys of their line--pricey but well worth it--they work extremely well
For our custom homes we use Dayton for overhead and for in-floor we use Heatlink--
When using any in-floor system, preparation, let me restate that Proper preparation, of the base, depth and mapping of tubing and components, care in concrete slab placement and finish are all critical--you must have a firm stable base for your slab--if prepping for an in-floor system be sure and work with the arch/designer/contractor make sure location of all desired floor mounted equipment is throughly noted and that everyone involved absolutely knows where it is/is not safe to drill mounting bolts etc. (been there done that--not real high on the fun factor)
On a smaller scale we've used in floor electrical wire grid bedded in setting compound under bath, dining and kitchen, patios covered and uncovered, using tile/marble/slate / hardwood flooring with excellent results--caveat though if one wire is broken on some systems the entire system is shut down--fix- trace down the culprit, tear up the floor, repair, replace floor--knock on wood we've not had that problem though I know of other builders that have.
Go with the Polycarbonate skylights--we use them exclusively--I built/remodeled homes 20 yrs ago using them and as far as I know they are just as good today as when first installed--the Mfg warranttys are just that, like a automobile, no lifetime guarantee
Different parts of the country have their own "local" window Mfg co.s--so what we use here probably isn't available in Ohio--of course you can go with the national known brands like Andersen, Pella, etc--pricey though for "name brand" recognition/quality that can be obtained from a quality local MFg'r at a more realistic competitive price.
If you have any questions during your build feel free to e-mail me and I'll help if I can---
Good luck and have fun on your new project--that is the key ingredient for having a successful build--have fun and try not to stress--
One note if you haven't already you might want to draw up a "performance" bond for all contractors and subs involved, including shop equiptment being made and delivered etc.--a good way for you to keep control and avoid cost overruns, etc due to contractor error or neglect.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
