Old 08-01-2003, 07:16 AM
FST HSKR FST HSKR is offline
Club Cobra Member
Did attend a class on this many many years ago thru Ford, use what ever paint you have left and fill in the area with paint using a brush, use a razer blade and scrape the excess paint off the high area. Hold your blade to be body so that the blade is standing straight up this will keep you from digging into all of the paint and will only scrape the high area. Keep applying paint untill the chipped area is full and level with the rest of the painted body after the last scrape use a fine rubbing compound to polish. The whole process takes some time put the finish will work. The gentelman that showed me worked for Ford and did this to new Lincoln's at the plant many years ago.
Hope this will work for you.
Jim
