Old 08-02-2003, 06:35 AM
George Snyder's Avatar
George Snyder George Snyder is offline
Lynn,
Yes.
The adjustment for the accelerator pumps are snug against the pump levers. The diaphrams are all OK. Good thought and thanks!
David,
Your jets sound correct. I am using 64 & 67 in the Holley now. It appears that I am running a little on the lean side when inspected the plugs. I am not too concerned with it as I am also running 89 octane gas. It seemed like a good idea for a little insurance until I was able to get the correct jetting and timimg set, especially the total timig. I need to avoid any detenation problems.
I can drop back to 87 when this is finalized, 9.0 CR. I do realize that the 87 will have a small effect idle caused by the fuel burning increased amount.
To be perfectly honest, I also simply decided to stop any more investment in jets for a carb I anticipated replacing. The Holley is eight years old and old technology.
Demon came with 70 & 78 standard. I am thinking it a waste of time to start with jets that high. I am considering say, 66 front & 70s or 72s rear. Timing at 16 initial, total 36-37 in at 2,600 -2,800.
I just need Air Borne to get the claim settled so I can get the new base plate shipped in from BG and get started.
Bud
