Old 08-02-2003, 04:20 PM
Junket's Avatar
Junket Junket is offline
Cobra Make, Engine: shell valley
Gary sounds like a vacuum leak if you are runing at about 1000 RPM or so like Ernie says as far as the temp not stabilizing belive that would account for a wrong air fuel ratio it also run lean build to mutch heat at uper rpms also would cause back firing.
Ken
Talent is your head in communication with your balls.
