Old 08-04-2003, 05:12 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
John: Let me know what size of heim joint and part number you get for the uppers. I just picked up a set of adjustables from Pete Clark and Pete said I may have to go to the heim joint. Pete also said to don't forget to put spacers in, or the heim joint will move around.
Bye the way, I had my rear welded up locally and told Joe T about the costs and he sent a check to almost cover the costs. Saw your thread about the Pig pointing up and mine is the same. That's why I had to raise the rear adjustable shocks up 3/4" so I did not bottom. There is a contact point on the frame cross member, so I got the adjustable bars to tilt the rear downward a little and hopefully can lower the car down a bit.
Jim
OhioCobraClub.com
