Old 08-04-2003, 04:34 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
My engine runs about 10 degrees cooler with a shroud that covers the entire radiator tightly with a rubber seal arond the edge and the fan taking up the entire hole. The other that I had was just the fan and frame up against the radiator....Big difference! I used a Flex-a-Lite Black magic 5.0 Mustang kit. The shroud has the relay, adjustable thermostat and control circuit built into the side of the shroud....Has a nice mounting system too... $200 complete..
Nice job Pete! Come this winter I see some changes being done to mine..
