Old 08-04-2003, 08:58 PM
TomH TomH is offline
Cobra Make, Engine: Virtual 2.4M
Send a message via AIM to TomH
H-D Trucks use them because of the long service life. Unless you get some that are designed to be "plug compatible" replacements for incandescent bulbs, the current draw on LED is too low to trigger turn signal relays.
The LED's brightness and its stark ON/OFF Bright/DIM transition makes it much more noticeable than the standard incandescent bulbs.
