Old 08-06-2003, 07:00 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Are you feeding the guage through a Voltage Stabilser? That should output around 10.5V from memory.
Even without one, the guage should read, if inaccurately.
If you short the sender wire to earth, you should get a needle deflection (probably violent, so don't hold the short for too long). If not, your guage is u/s. It is a Smiths guage after all. Sorry.
HTH
Wilf
